-   -   Water in drive shaft bellows (https://www.offshoreonly.com/forums/drives-lower-units/350350-water-drive-shaft-bellows.html)
jeff32 10-16-2017 10:04 PM
besides the cracked bellow, or if not sealed properly in both ends, what else could bring water there?
Falcon 10-16-2017 10:11 PM
Bravo? If so, the front edge of the drive seals against the exposed edge of the bellows. If the drive edge gets damaged or if the edge of the bellows takes a set from another drive on it, it may not seal against the edge of the drive.
compedgemarine 10-16-2017 10:47 PM
did this just start or was something replaced and now it leaks?
jeff32 10-17-2017 05:58 AM
Just started i guess
BBYSTWY 10-17-2017 06:35 AM
is there water in the shift cavity?? meaning where the shift cable hooks to the bracket....if so ive seen it where the back cover was warped allowing water in there and then cracked the oring on the shift cavity and allowed water in the bellows...or the water hose gasket was bad it leaked straight down onto the shaft and it then went in the bellow or the boat simply filled up with water at one time and it came in the front past the shaft orings
good luck!!
Stewart
JaayTeee 10-17-2017 04:48 PM
Is the bellow sleeve in place?
jeff32 10-21-2017 08:59 AM
yes in place! will look again more closely... thanks for the opinions!
veloc410 12-04-2017 06:11 PM
Maybe corrosion between mating face of bell and outdrive
