-   -   Oil line plastic clamps (https://www.offshoreonly.com/forums/drives-lower-units/350582-oil-line-plastic-clamps.html)
kip4234 10-30-2017 10:36 AM
6 Attachment(s)
what is everyone using on the bravo oil lube line from the housing down to the helmet on the outdrive. Do you use the factory plastic clips ? my new oil lines seems to large on the outside diameter to use these using stock factory mercruiser line which is parker hose?? or do you use something else ? I thought I had complete stainless hose clamps but realized the screw portion was not stainless.
Clustergear 10-31-2017 06:37 PM
Use wire ties, but use the good ones with stainless tab. The small T&B ones
underpsi68 10-31-2017 07:17 PM
What is the outer diameter of the hose?
dunnitagain 11-01-2017 08:31 PM
Use a good wire tie , or the herby clamps that are supplied . The good hose fits so tight you have to cut it off anyhow.
kip4234 11-02-2017 06:51 AM
Thank everyone, I am going to use the good zip ties on this,
