-   -   alpha SS on gen 2 gimble (https://www.offshoreonly.com/forums/drives-lower-units/352305-alpha-ss-gen-2-gimble.html)
94sylvan 02-14-2018 10:06 AM
I've read several times that its been done, but has anyone ever documented the procedure to modify an SS drive to mount to a newer gen 2 gimble?
ACrooks69 03-28-2018 03:38 PM
I'm one who has done it. I didn't document it per say, but I remember what I need to do.
94sylvan 03-28-2018 05:02 PM
Thanks ACrooks69. I'll message you once I locate a drive to get some pointers. I have found a couple issues that may be part of my speed problem we talked about earlier this winter. Need to fix those first.
firefox1 05-17-2018 02:50 PM
I have done it also. PM if you need any info. I have custom Alpha SS wear pad and trim pin spacers for the Gen2 gimbal ring and trim pin.
robertconley7 12-07-2024 09:20 AM
Hi i have an alpha 1 gen1 od and I needed a new gimble housig i get a gen 2 that is in exellent condition with rams and bell housing ,that i can't return i have installed the gimble and bell housing to the gen 1 transome with no problems so fa all bots and everything lined up having trouble with egine allignment and i see that you have done this before any help would be appriciaited Thank you nsio much Robert Conley
robertconley7 12-07-2024 09:23 AM
Hi I would love it if you could share with us your knowledge thank Robert Conleyonley
