-   -   Bravo XR Upper Pinion Gear Shims (https://www.offshoreonly.com/forums/drives-lower-units/354090-bravo-xr-upper-pinion-gear-shims.html)
Seahawk 2000 05-21-2018 08:23 PM
When I removed the pinion gear from the bearing assembly there was two brass looking shims (.003 and .010) that do not show up on any exploded view to be able to purchase. So I called Mercury and they didn't know what it was. The shims in the photo are a little mangled because I broke them. Help! https://cimg3.ibsrv.net/gimg/www.off...3fcf23cea1.jpg
JaayTeee 05-21-2018 10:04 PM
I recall seeing somethinglike those on an old IMCO SC....might check with them...you can accomplish the same thing by using the later style ( an OW above) pinion bearing that uses shims to set the pinion height in the housing, there is a special tool used to do this, the spec is .025
Seahawk 2000 05-21-2018 11:14 PM
OW? Not sure what that means
JaayTeee 05-21-2018 11:47 PM
serial number range OW..
Seahawk 2000 05-22-2018 11:11 AM
Is it Drive Shaft Pinion Gear Shimming Tool 91-42840T?
JaayTeee 05-22-2018 12:29 PM
91-865114T is what I have
Seahawk 2000 05-22-2018 05:57 PM
Thanks!
