-   -   SSM 3 Setup (https://www.offshoreonly.com/forums/drives-lower-units/356308-ssm-3-setup.html)
glastron 08-28-2018 01:14 AM
SSM 3 Setup
Can someone give me the distance from bottom of boat to centerline of outdrive lower? (nose cone tip)
resurrected 08-28-2018 07:20 AM
https://cimg4.ibsrv.net/gimg/www.off...cd3534d6a8.jpg
On my 30' single step with twin blown 454s its 5" when parallel to the running surface
I don't know if it right or wrong I just bought the boat this summer
It is difficult to get on a plane, looses traction easy
glastron 08-29-2018 12:56 AM
Thank you for your help. What props are you using?
resurrected 08-29-2018 07:30 AM
Happy to share my experience (for what its worth!)
They are 16.5 x 29", I don't know the make
I don't have solid data, I flattened a cam early on in the season
Re-building the engines so I'll need bigger props anyway
I wise man once told me if it breaks, fix it faster!
