-   -   Bravo/Bravo xr input shaft (https://www.offshoreonly.com/forums/drives-lower-units/356542-bravo-bravo-xr-input-shaft.html)
Mattymach1 09-08-2018 03:19 PM
Hello guys,
When I bought my boat the bravo one drive was upgraded with a bravo XR yoke(bigger ujoint cap 1.329) to the drive however the center carrier and shaft to the engine are standard bravo one(smaller standard ujoint 1.07). The center carrier snapped and I need to either get another standard center carrier and use the bigger ujoint (862132T) for the drive yoke and add smaller caps to the center carrier side.....or get a new center carrier that will take the 862132T u joint.
Does anyone know the part number for the bigger center ujoint carrier that uses ujoint 862132T. As well as the shaft to the motor?
or could I just put smaller ujoint caps on the standard center carrier side of the ujoint. Im not sure if the inner diameter of the caps change and are interchangeable.
any help is appriciated.
