-   -   Transom assembly (https://www.offshoreonly.com/forums/drives-lower-units/357062-transom-assembly.html)
Coreconstruction 10-07-2018 10:17 AM
Transom assembly
Who has the best price on the hp transom assembly,
I am upgrading my drives and while everything is apart I want to change or rebuild my transom assembly
AllDodge 10-07-2018 11:06 AM
Bought mine from Coastal Marine Export (Mike Wood) but note that if comes in broke he may send previously installed new parts and you have to do the repair. Bought one HP and all good but did not have trim sender. Sold it to another member and bought another with trim sender. The second one came it not packaged as well and the Mercathode was broke. I was sent another Mercathode which was cut off another assembly. This means I had to solder the wires together instead of getting a new unused Mercathode
Other then that, look good and is still on the boat today
