Its transom assembly
Will a regular bravo drive to on a it's gimble???? Thanks
yes...........but you need the longer in put shaft
Also if you have a standard bravo 1 (not a X, XZ, or XR) you will have to have a custom drive shaft made or do what I did and sent the drive to AADS and have it converted from a bravo 1 to a bravo 1X. The ITS drive shaft (from MERC) uses the larger U joints on found on the X,XZ,&XR drives so its not as simple as changing the standard length shaft out for the ITS shaft. I documented the conversion on my thread if you want to check it out. Also you have to go full hydraulic to the helm for the ITS to work. A cable to a add on system won't work. Trust me I tried.
https://www.offshoreonly.com/forums/...outlaw-15.html |
