anybody ever hear of Omega 690 gear oil? >
Like Tree1Likes
  • 1 Post By SFOcean
Old 12-14-2018, 01:51 AM
Default anybody ever hear of Omega 690 gear oil?
looks interesting, anyone ever hear of it?
offshorefisher is offline
Old 12-14-2018, 09:23 PM
Charter Member #394
Sure has some serious tackifiers in it.
SB likes this.
SFOcean is offline
Old 12-14-2018, 09:28 PM
SB
Not all gears set up's need 'climbing' gear fluid. There are lots that do this -not ust that Omega oil. The housing and/or cover/wall/channel/sump shapes +other things have a lot to do with it. Meaning. some environments fully bath the gears without the tackifiers to make the oil climb.
With that said: Would be great to see a cut-a-way of a Bravo one and see the oil while the gears are moving.
SB is offline
Old 12-14-2018, 10:58 PM
The CenPeCo stuff looks about the same. It would be interesting to give it a try. I wonder if it would be cone clutch death.
Old 12-14-2018, 11:05 PM
BUP
rising gear oil in the Merc app might not be a good choice as it might over come the internal pressure and dump out where ever --- like over flow out the gear oil reservoir bottle or the other side of it is --- if it builds too much pressure that can blow past the propshaft seal ? As the gear oil rises - it takes up space so I can not help thinking about that smaller space building more and more pressure on top of ?? Just thinking out loud
BUP is offline
Old 12-15-2018, 05:45 PM
Charter Member #394
BUP, that has happened to a few drives running RedLine Shockproof Heavy, also a high tackifier oil. Myself and a few others wrote it off to foaming - seems the high tackifier may be problematic also? Shockproof oil also doesn't mix with water - if you get some water into the drive, the oil really 'foams' and goes everywhere as you describe. BTW, I like Red Line products LOL.
SFOcean is offline
Old 01-05-2019, 09:29 PM
+1 on the redline shockproof and my dad's boat. Makes sense either way.
ACrooks69 is offline
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
