-   -   Bravo Ratios in X vs XR (https://www.offshoreonly.com/forums/drives-lower-units/358908-bravo-ratios-x-vs-xr.html)
Keith Atlanta 02-05-2019 08:33 AM
Guys, does anybody have ratio charts for X vs XR drives?
Also, as it applies to the 1 inch vs the 1.25 shaft ratios.
offthefront 02-05-2019 03:43 PM
Not sure if it matters on prop shaft Size ... Also everyone always claims Overall Drive ratio is determined in the lower ...I dont think thats always true ....
https://cimg9.ibsrv.net/gimg/www.off...e7e93156ba.png
IGetWet 02-05-2019 04:02 PM
Pretty sure overall ratio is a combination of the upper and lower ratios. Maybe not on the X though.
Sterndrive Gear Ratios
AllDodge 02-05-2019 04:59 PM
Shaft size has no impact, its all gears (top and bottom)
Here is the X
https://cimg1.ibsrv.net/gimg/www.off...c5a8cdad58.gif
dsmawd350 02-05-2019 05:53 PM
With an XR the gear ratio is always determined in the lower. As you can see in the chart the upper tooth count on the XR is always the same . The ratio is changed with the lower
