-   -   bravo xr u-joints (https://www.offshoreonly.com/forums/drives-lower-units/358920-bravo-xr-u-joints.html)
Cas22drummer 02-05-2019 08:02 PM
bravo xr u-joints
Is there a u joint that will work in a bravo 1 xr swept back drive other than the merc ones that are over priced?
offshorefisher 02-17-2019 04:36 PM
I’ve spent quite a bit of time looking and I have not found any that match.
IGetWet 02-17-2019 06:22 PM
I went to a large bearing shop/distributor that deals wih about every know u joint known to man. After about 45 min of measuring and looking up part numbers, 3 or 4 of their guys could not find an exact replacement. Sounds exactly like how mother mercury operates to me with other parts.
BUP 02-18-2019 01:23 AM
The U joint depends on Bravo XR serial number.
If you do not know your drive serial number you can send me the U joint to verify which one you have to match it up.
