-   -   What is purpose of drive splash plates (https://www.offshoreonly.com/forums/drives-lower-units/360421-what-purpose-drive-splash-plates.html)
rvtransport 05-03-2019 11:41 AM
Installing some IMCO SC lowers on my XR drives and wondering the purpose of splash plates are above the propellers? I was told some guys do not run them. Do they just lesson rooster tail or do they actually do something else?
Baja Rooster 05-03-2019 12:11 PM
If you’re talking about the cavitation plate I believe it helps the bow nose over and keeps water into the prop for more bite. These are just tid bits of info that I’ve read on the internetz.
VoodooRob 05-03-2019 12:21 PM
^ This is what I was told by George at All American.
madbouyz 05-03-2019 12:38 PM
If you made the unit without 'em when you put the unit in gear water starts heading for the prop from all directions . You'd even get a vortex on the surface like water going down a drain.
They're actually 'anti ventilation plates' to stop the prop unnecessarily ventilating . The word 'cavitation' is very commonly used incorrectly .
rvtransport 05-03-2019 01:52 PM
Makes sense to me. Thanks for the info! I will order the plates now. :)
madbouyz 05-03-2019 04:37 PM
OK , I'm a bit puzzled . How do you order them and put them on ? If we are talking about the anti-ventilation plate(s) they're an integral part of the lower unit's structure and are all cast as a one piece casing when they're made. I woulda thought you either have them or you don't .
Baja Rooster 05-03-2019 05:00 PM
Are you talking about those bolt on rubber fins that under powered fishing boats use?
IGetWet 05-03-2019 07:49 PM
Pretty sure he’s referring to these pieces, splash plate https://cimg8.ibsrv.net/gimg/www.off...83e1163816.png
IGetWet 05-03-2019 07:51 PM
I tried running a 4 blade bravo on my Outlaw without one and it’d blow out every time trying to plane.
rvtransport 05-04-2019 09:04 AM
Thanks for info. See you at Four Horseman this year?!
