-   -   Alpha 1 Gen 2 make it stronger ? (https://www.offshoreonly.com/forums/drives-lower-units/361405-alpha-1-gen-2-make-stronger.html)
Donzi Z22 06-23-2019 09:04 AM
Can A Gen 2 be built to handle 450 hp by changing gears ?
Bondo 06-23-2019 07:38 PM
Ayuh,....... Ya change out the Alpha gears, to Bravo gears in a Bravo drive,.....
Donzi Z22 06-23-2019 07:45 PM
Can you explain,you can change the gears to make the Alpha Gen2 stronger ?
Bondo 06-25-2019 05:05 AM
Ayuh,.... You ditch the Alpha, 'n go with a Bravo drive,.....
