-   -   Bravo (https://www.offshoreonly.com/forums/drives-lower-units/362531-bravo.html)
tripps 08-20-2019 08:13 PM
Bravo
Ok I got a23 Daytona w bravo and BBC trying not to break it anybody shift on starter??? Cranking and put in gear!!! How about starting in gear??? Any body run Nitrus on a bravo ??? It's a 3500 lb boat 28 bravo,1.5 drive runs 5100 5300 on the wind motor makes 510 on dyno at 5500 ????
Griff 08-21-2019 12:51 AM
Why would you think starting in gear would help??
Mightyhardlivin 08-21-2019 05:03 AM
Yea, I wouldn't do any of that..... as far as N2O goes, how are you going to prop your boat? The time that you are pushing the button or the time you're not. Either way your going to be propped wrong.
tripps 08-22-2019 07:07 PM
Bravo
I had a 24 MY boat 30 years ago had a BBC e speedmaster drive went 90 at 6000 had nitrus hot button motor really turned on 1000 rpm more ,boat launched all over again at 90 ,I know there is power ,but can a bravo handle 150 more at wot??? Lite boat ,prop 2 below other boat was full tunnel prop was even with sponson
tripps 08-22-2019 07:10 PM
Bravo
Start in gear so not to crash come clutches ,crash gears at 800 rpm just asking motor starts instantly
Mightyhardlivin 08-22-2019 07:39 PM
There are bravos handling big power all over the place. No need to reinvent the wheel.
JaayTeee 08-22-2019 07:52 PM
800 rpm idle shifting is just fine, low teens and up can be a little hard on it
