-   -   Bravo 1 not shifting once it’s warmed up. (https://www.offshoreonly.com/forums/drives-lower-units/363059-bravo-1-not-shifting-once-%92s-warmed-up.html)
99Fastech353 09-22-2019 04:41 PM
When the drive is cold it shifts fine but after running for awhile and shifting into neutral it won’t go into either gear without giving it a little rpm then it shifts into gear.
Clustergear 09-22-2019 08:08 PM
First place to look is drive oil burned and piss thin.
Griff 09-23-2019 12:59 AM
What drive lube are you using??
