-   -   Alignment Tool Recommendation (https://www.offshoreonly.com/forums/drives-lower-units/363644-alignment-tool-recommendation.html)
afratki 10-29-2019 11:34 AM
I have a 2005 Formula w/Bravo III's that I'm looking to purchase a drive alignment tool for. The tool from Merc was a little pricey and was looking at or similar. Any thoughts for a DIY'er?
phragle 10-29-2019 12:18 PM
Oso member whoya he all
so sells them on ebay
F-2 Speedy 10-29-2019 12:28 PM
https://cimg7.ibsrv.net/gimg/www.off...6e6b13b16d.jpg
BUP 10-29-2019 12:43 PM
Actually Sierra has a good alignment tool or use to. I have one from Sierra, I bought many many years ago. It is very heavy and a very high quality piece. I have a lot others as well Including the Merc OEM and the aftermarkets. Some aftermarket are cheap quality.
With that said I can not verify if Sierra Alignment tool is the same quality as per when I bought mine 20 year ago, Possible still worth the buy. I am not a fan of most Sierra products but YES for the Alignment tool I bought 20 years ago. If it is the same I would buy that in a heartbeat. Also I have the installer mandrel that adapts to the alignment tool. U do not have to drill the hole alignment tool either. U slide it on the tool and makes for a super easy install of the GB. Also the GB is aligned as well using the tool. If in fact your alignment is good from the start.
I check on all that if one needs this set up. The tool and install mandrel.
afratki 10-29-2019 04:04 PM
Thanks for the replies everyone. I'll reach out to whoya and check out the one from Sierra.
phragle 10-29-2019 09:37 PM
https://www.ebay.com/itm/Boat-Engine...AAAOSwjlVcLoCP
speicher lane 10-30-2019 05:56 AM
FWIW - a machine shop would charge WAY more than the $23 from ebay just in the hourly shop rate to put the bar in the lathe much less cut it down to profile
whoya 10-30-2019 07:35 AM
Shoot me a message at [email protected].
Helmwurst 10-30-2019 08:56 AM
Bought mine years ago at Mercstuff.com The actual business is or was Precision Services Inc. Shelby Township, MI 586-739-4782. Bought stuff from them just this past Summer for my outdrives.
