Bravo 1 loose steering
So I have a 98' bravo 1 on a commander boat. If I grab the drive I can swing it side to side about three inches. There is basically no play if I move it up and down. It has the jr marine cover on it so I'm assuming the previous owner did the swivel pin and ring.
The u bolt is at 55lbs where it should be and if I look up at the swivel pin at the bottom of the ring the pin is moving with the ring when I move the drive side to side so I dont think it's the gimbal ring. If I have someone move the drive side to side and watch the tiller arm inside the boat, it does not move. However, if I have someone turn the steering wheel while I watch, two things happen. The Initial slack in the steering wheel, before the tiller arm moves, is caused by the steering cable housing sliding about 1" in the actuator and then the tiller arm moves. As soon as the tiller arm moves, the drive moves. I dont get it. To recap: the tiller arm does not move if you wiggle the drive side to side and watch it but if you wiggle the steering wheel as soon as the tiller arm starts to move so does the drive. What gives? Is it play in the pin where the arm connects to it? But why would the drive move as soon as the arm does using the steering wheel but not if you wiggle the drive? Please help and sorry for the long post! |
To recap: the tiller arm does not move if you wiggle the drive side to side and watch it but if you wiggle the steering wheel as soon as the tiller arm starts to move so does the drive. Remove the tiller arm pin, and try to move tiller arm by hand |
Originally Posted by AllDodge
(Post 4725141)
That's a head scratcher
Remove the tiller arm pin, and try to move tiller arm by hand Like said above, disconnect the steering pin directly from the tiller arm and then you will most likely feel that slip in the tiller arm. |
Originally Posted by MyIsland
(Post 4725149)
i installed 2 of them updated swivel pins on my drives. Your issue sounds like the tiller arm “square” that goes over the new swivel pin was not replaced and is worn. So when you move drive back and forth it does not move because it is held in place by the tension of steering system.
Worn tiller arm
Yep I disconnected the steering to tiller arm and I can wiggle it, time to replace the tiller arm or more?
By the time you get the tiller arm off, you will know if anything else is toast.....
Originally Posted by rspillman88
(Post 4725189)
I beleive you will be at the very least dropping that pin through the gimbal ring to get the tiller arm out. In doing so you may as well inspect that gimbal ring “ square” socket at top and make sure it’s not worn. It is my understanding as well that you will be loosen the u bolt you see on top of gimbal ring to do all this, so you should replace that ubolt as well to get the proper torque. It is sad that someone went through all this work once and sounds like they did not replace that tiller arm. That JR marine pin and the rework they do on the gimbal is a solid better than OEM repair. |
So being that the gimbal ring appears to be tight because the swivel shaft moves with it as I move the drive by hand and the tiller arm wiggles when disconnected, would this be a good time to do a single ram hydraulic add on? I would eventually switch to a full hydro just dont have the funds for that at the momen. Just curious because instead of spending the money on replacing the tiller arm I could just do an imco add on. The boat runs 64-66mph
The Imco add on works fine , Ive done several . Its a good addition to boats in your speed range .
Make sure the tiller arm cross bolt is tight and that the swivel pin nut is snugged down on the tiller arm. Ive seen the bolt through the tiller broken , it lets the tiller square spread and makes it flop. |
Originally Posted by dunnitagain
(Post 4725542)
(Post 4725552)
okay but would it be okay to install that when I already have slop at the tiller to swivel pin connection? Or do I need to fix that first then do the add on steering?
(Post 4725560)
you don’t need the tiller arm connected to steering linkage with add-on ram. BUT you just need to make sure the nut on top of the swivel pin, up inside that plate on Gimbal housing, that sits on a washer on top of tiller arm is snug. The tiller arm still provides the spacing to tighten that swivel pin. You want to just make sure that is 100 percent.
(Post 4725574)
okay that makes sense and I will check that. If I still have the proper spec of .002-.010 clearance at the bottom pin would that be a safe way to assume the nut is tight on the swivel shaft top of the tiller arm nut?
but what be sitting in my mind still would be if the tiller arm is not busted. If someone put that plate on top of drive, I’m assuming they put a new stainless swival pin and seal. They should have put a newly conditioned gimbal ring and at that pt a new tiller arm, which they clearly did not. I’d want to make sure that arm is not busted. |
Its the steering on a boat that goes relatively fast on rough water. Provided you do not like leaks that eat transoms, unintentional swimming lessons or yourself, family and friends getting injured or worse....If there is the least question in your mind, take everything apart, inspect it and repair/replace as needed.
(Post 4725599)
Id say yes!
| All times are GMT -5. The time now is 09:23 AM. |
