Bravo xr vs Bravo one propshaft
I have a bravo one and the propshaft is twisted pretty bad, I acquired a labbed 29 hydro QIV that has a welded in 1 1/4" hub I was wondering if a bravo xr 1 1/4 propshaft will go directly in the bravo one or do you have to buy the whole prop shaft kit? If so what are the differences are the splines inside the lowers different or the same? Just trying to save a few $$$
I believe you just need the 1 1/4 shaft and the bearing carrier . I think the lower gears are the same.
Gears are the basically the same except the XR gear has a larger bore to fit the propshaft. Probably better to buy the kit then to bore the gear out.
With this conversion kit, you use your current gears
https://www.cpperformance.com/p-1573...rsion-kit.aspx |
