-   -   Merc II trans (https://www.offshoreonly.com/forums/drives-lower-units/366177-merc-ii-trans.html)
thunderboatr 05-04-2020 11:16 PM
Merc II trans
I purchased a Cig 28 that had not been winterized properly leading to both blocks cracking. I pulled one out today and it left me wondering about the transmissions. Anything I should check that could have gone bad when it froze?
rws 05-07-2020 10:45 AM
Check the oil coolers.
Down on side near bottom .
Square plate with 2 hoses coming out of it.
flashgordon 05-09-2020 08:56 AM
is this a c-72 borg warner velvet drive trans????
what ever trans it is ,,,,yea ,,as mentioned check the trans oil cooler.
Mr. Cool 05-12-2020 09:45 AM
I'm not sure what the application here is. But the plate coolers commonly split along the sides. If it's a tube and shell you may have just popped an end cap or you could possibly have split one of the cooling tubes which is a little harder to tell visually. A quick pressure test should tell. You're not looking for a champagne bubble leak. You'll likely have something significant.
