-   -   Bravo 1 Oil Leak - Need Help (https://www.offshoreonly.com/forums/drives-lower-units/366190-bravo-1-oil-leak-need-help.html)
mbobb 05-05-2020 01:25 PM
I'm running into an issue on my Bravo 1 where it leaked a little oil out of the side-water pickup this winter……my Bravo 1 only has the side water pickups (not the dual setup). I looked through some old threads that mentioned the Quad Seal and also some small O-Rings to replace when you separate the upper/lower units. Does anyone know the part #'s for the Quad Seal and required O-Rings? I found a kit but it's $60 and appears to have a lot of other seals I don't need. Do I need part's #4 and #5 on this diagram? https://www.hardin-marine.com/s-5533...ortmaster.aspx
bencini231 05-05-2020 02:42 PM
I always buy #4, #5 and #17 when I'm putting the lowers back on. all of the Merc part #'s are in the first row listed as OEM Part #.
mbobb 05-07-2020 06:52 AM
Ok great, thanks for the info! I couldn't see buying an entire kit when I just need a few of the parts.
