-   -   Erratic number 6 drive trim indicator reading (https://www.offshoreonly.com/forums/drives-lower-units/366823-erratic-number-6-drive-trim-indicator-reading.html)
hardcore 06-10-2020 07:25 AM
Hi guys, I have a 2015 700/number six drive package in my boat. Yesterday noticed port drive trim reading was off by 10 to 15 points compared to starboard. Reading is on the vessel view and actual drive position is okay when trimmed together with the starboard drive. Anyone have any expierience in tracking down this problem ? Any help would be appreciated. Thanks.
Mark
Got Freedom? 06-10-2020 10:14 AM
Make sure the two screws holding the sender down are secure and it didn't move. Also look for excess play in the drive, gimbal or trim ram that may have caused the change. If that checks out then I would start by re-calibrating your trim settings in VesselView. If that doesn't work then it's probably the sender.
GF?
hardcore 06-10-2020 11:29 AM
Great, thanks for the reply , I will check all that out .
