-   -   Bravo 1 help (https://www.offshoreonly.com/forums/drives-lower-units/367396-bravo-1-help.html)
Jase 07-10-2020 08:17 AM
Bravo 1 help
Hi, my bravo 1 seized last week I got a rebuilt. There were only 2 gaskets on the drive a rectangular sorta gasket and one around the shift cable. What prevents water from seeping in around the 6 bolts mating point? There was no gasket there
actionmarineguy 07-10-2020 11:44 AM
the bellows seals the driveshaft. no gasket on bravo drives only 2 round o rings and one formed o ring Alpha drives use a gasket.
Jase 07-10-2020 01:11 PM
I only found 1 o ring around the shift cable. Where is the second?
Donzi1979 07-10-2020 01:52 PM
The other round o ring is a thin one where the remote gear lube port mates.
JaayTeee 07-10-2020 01:53 PM
The other seal is a formed o ring for the inlet water passage on the l/h side, that’s it
Jase 07-10-2020 05:25 PM
Thanks for your help. But now at the putting the drive back on moment, I checked the coupler to he sure it wasn't screwed up when my old drive seized. I think this is bad , but im not a mechanic. The splines are triangular not square ,Is it usable for another month or needs changed now?
Griff 07-10-2020 11:11 PM
Are they splines sharp???
Either way, unless you have time to pull engine and replace the coupler, I'd put it together and use it. Worst case is coupler goes out
