-   -   Need Bravo 1 lower unit built this week in Atlanta (https://www.offshoreonly.com/forums/drives-lower-units/367482-need-bravo-1-lower-unit-built-week-atlanta.html)
aquaforce 07-14-2020 09:20 PM
Need Bravo 1 lower unit built this week in the Atlanta GA area. Do you know someone? Are you someone who can build my B1 lower this week?
HELP.
My lower unit started leaking again and I don't have time to do anything with it before the Hartwell run. If I can get this one built or find a good used drive for my 97 model Bravos I could make the next two events we planned. seven7zero3six3zero1two7
TIA
Unlimited jd 07-14-2020 10:24 PM
What about buying an Sei lower?
Griff 07-15-2020 12:51 AM
SEI Bravo lowers are $995 with a 3 year no fault warranty. Only negative I've heard about them is the paint does hold up as well as Merc.
https://www.sterndrive.cc/Mercruiser...ower-Only.html
aquaforce 07-15-2020 06:42 AM
Yes, I've thought of that too. It may be a viable option given the short time I have to work with.
aquaforce 07-15-2020 08:56 AM
Update: wow what a pizzer. SEI doen not have any !!!!!! They are back ordered and do not have any idea when they will have them.
I still need a single pick up lower. Help.
F-2 Speedy 07-15-2020 09:31 AM
Call the bravo shop @ LOTO
ThisIsLivin 07-15-2020 11:06 AM
Call George at AADS 517-858-1043. He's turned my stuff around quickly.
aquaforce 07-15-2020 03:22 PM
That worked well. They also told me my problem in the lower is caused by my upper coming apart and pressing the vertical shaft down causing the leak. Not good. Now I need an entire drive. they have an X series but I'm not at $7K for that one.
So a good used standard bravo 1:5 for 97 model application is what I'm after in time for the Hartwell run by the 22nd. Something that is good enough to run while I build mine.
aquaforce 07-15-2020 03:24 PM
That was a fax number. Who is AADS?
F-2 Speedy 07-15-2020 03:53 PM
All American drive service
