Bravo one X to XR conversion cost >
Old 10-29-2020 | 03:51 PM
Default Bravo one X to XR conversion cost
Does anyone have a ballpark for parts and labor to do this conversion? I'm starting with a '04 Bravo one X with 400hrs, unit performs great. In looking at the parts breakdowns it appears there are a fair amount of common parts like the vertical shaft, housings, etc.
Thanks!
87MirageIntruder is offline
Old 10-29-2020 | 04:05 PM
Dude, if you have an X that is in great shape at 400 hours STAY WITH IT! Break it open and replace the upper gears if needed. You'll never get half the hours out of a set of upper XR gears. Plus XR's will eat a tad bit of speed and they are louder (heavy gear noise). Some people are seeing better performance out of X drives anyway.
Keith Atlanta is offline
Old 10-29-2020 | 04:12 PM
Keith thanks for the reply! Do you think a freshened X drive can handle 600+ HP in a single 28'?
Old 10-29-2020 | 04:19 PM
Awe jeesh, here we go. I have had gear pitting issues on XR's ever since I went to them with my 600's. With both stock new and cryo treated gears. There will be a hundred opinions and science behind both. For example, there is more gear surface carrying the load with the X gear tooth but the base of and XR gear tooth has a thicker base. I have a hard on for hatred against XR gears. But, my vote is still for the X gear set. Lets see how everyone else chimes in.
Old 10-29-2020 | 04:26 PM
In the reading I've done on here (and many posts from you Keith) it does seem there is a difference of opinion on XR gears. Max Machine in Havasu said there were some bad runs of XR gears for a while, but now things seem to be better.
Also for clarification, my X drive has 400hrs behind a stock 496HO. I just dropped in a 600+ HP whippled engine so I need to do something. I'll be running a bravo 4 blade likely 28 or 30P with 1.5 gears on a Nordic Heat 28'.
Old 10-29-2020 | 04:55 PM
Run it until it blows and then swap in a new XR upper. Have towing insurance if boating offshore.
thirdchildhood is offline
Old 10-30-2020 | 06:51 AM
Why not just bite the bullet and go SCX upper with an XR lower? Seems like people have found this setup to be more reliable and cost affective after a year or two. I have a single 28 Pantera and I am on the hunt for an SCX upper. I don’t want to have drive issues running the boat when I’m out. Time is more valuable.
MMatt28 is offline
Old 10-30-2020 | 07:32 AM
What is the cost of a new SCX upper and new XR lower?
underpsi68 is offline
Old 10-30-2020 | 07:34 AM
Around 15K
snapmorgan is offline
Old 10-30-2020 | 07:40 AM
An all new SCX with an SC lower will cost about $17,900. You would never break it at that power level. If you are intesteded I'm going to have a freshly rebuilt IMCO SC-3 inch shorty complete drive for sale. It is not as strong as the SCX but will hold up better than the XR for sure.
Andrew56 is offline
