Bravo upper case vs. XR case
Is a stock bravo one upper case the same as a Bravo XR upper case? Can the internals be swapped from one to the other?
Short answer - no & no
The X cases are larger in the snout where the pinion bearings are housed
You can install an XR upper on any standard B1, 2 or 3 lower
Originally Posted by Satisfaction
(Post 4766198)
(Post 4766198)
| All times are GMT -5. The time now is 12:51 AM. |
