| kreese1983 |
11-30-2020 12:57 PM |
mercrusier Bravo 3 trim fluid capacity?
Hey Guys, Does anyone know how much fluid the trim pump and pistons take as a total? my one trim pump was totally dry empty. I tried to bleed to pump itself and after a hour or that. I got a semi solid stream of fluid. Connected the lines and I literally went through 2 gallons of fluid and still nothing. Its taking the fluid in as I hit the trim switch but I just do nott see it taking 2 whole gallons in the system?? I do not see anything leaking at the pistons and the drive is not moving at all. Any help would be much appreciated.
Boat is a 2005 Formula 37PC 496mag/bravo 3 outdrives.
