Need to Replace Bravo One Shift Fork??
Recently bought a boat with a very rough B1 sterndrive. Corrosion got the best of it. The lower needs to be replaced for sure, but I am trying to recondition the upper. It shifts into forward fine, but there is some hesitation when trying to engage reverse. It doesnt seem to engage until I give it some throttle. Anyway, this past weekend I opened her up and removed the **** assembly. The shif cable bellow was no good and consequently, the shift linkage had corrosion and needs to be replaced. When I pulled the shift fork, I noticed some wear and scoring on it.
I am not new to boating, but am new to Mercruisers and Bravo's. Previously owned Volvo Pentas. I am not sure if this wear is normal or if I should be concerned that it's an indication of bigger problems inside of the clutch assembly. I don't want to continue to spend time and money putting lipstick on a pig for nothing. Any advice would be appreciated. https://cimg6.ibsrv.net/gimg/www.off...fef963c01f.jpg https://cimg7.ibsrv.net/gimg/www.off...34bb0c91e3.jpg https://cimg8.ibsrv.net/gimg/www.off...e27299e08e.jpg https://cimg9.ibsrv.net/gimg/www.off...526a269da8.jpg https://cimg1.ibsrv.net/gimg/www.off...c4a002ed7c.jpg https://cimg3.ibsrv.net/gimg/www.off...1de9a1b176.jpg https://cimg4.ibsrv.net/gimg/www.off...1d0332c0b2.jpg https://cimg5.ibsrv.net/gimg/www.off...b51125e8d0.jpg |
A delay in shifting usually is from the cone clutch worn out
| All times are GMT -5. The time now is 04:22 AM. |
