Identify drive/Check drive oil...
My (new to me) drives do not have serial #s printed in the stripe on the units. I am trying to determine if there is a serial # stamped somewhere so I can identify the lower unit and then figure out how to check/service the drive oil.
My last set of Bravo drives had the drain plug behind the prop and a fill on the top side and a dipstick on top. My current ones have a Hardin Sport Tech Outdrive Cooling Shower on top and I did not want to introduce any more variables by removing/loosening it to see if there was a dip stick underneath. THANKS! https://cimg9.ibsrv.net/gimg/www.off...650c38198a.jpg |
Isn't there a drive lube bottle mounted on the transom in the engine bay ? post a pic of the lower
(Post 4786315)
Lower unit attached. THANKS for the quick response! https://cimg1.ibsrv.net/gimg/www.off...7dc8dd04f8.jpg |
There is no dipstick. The drive lube reservoir tells you if they are full
(Post 4786315)
looks like a standard swept back B-1, drain plug will be behind the prop
Originally Posted by F14A water jet
(Post 4786330)
No drive lube reservoir on the transom that I can see.
(Post 4786332)
it could be mounted on the engine ?? what engines are in it
Can you see anything... https://cimg5.ibsrv.net/gimg/www.off...f379dbe687.jpg https://cimg5.ibsrv.net/gimg/www.off...cd27402cd2.jpg |
(Post 4786331)
Found it...I was just looking from the wrong angle...
https://cimg3.ibsrv.net/gimg/www.off...c95a906fe4.jpg |
| All times are GMT -5. The time now is 04:37 PM. |
