1990Bayliner CIERA 2556 Difficult to restart the engine
Please help us.
We’re working on repairing the following ship’s engine, but it doesn’t work. •The engine is 7.4L BRAVO GM 454 V-8 •The ignition system is Thunder bolt5 •The engine serial number is OC869161 <The condition> When the engine is cold or immediately after warm-up, it does work. When over 30minutes have passed after the engine stopped, it doesn’t work even with the accelerator pomp. The engine gradually starts up, when we start the starter motor and open the throttle slowly. It also does work, immediately after this, but after over 30minutes, it doesn’t. <already replaced parts> Fuel pump Fuel filter Ignition coil Spark plugs Picup sensor Distributor cap Rotor Exhaust carburetor Thermostat Rush adjuster Intake manifold gasket Starter motor |
You might have better luck posting in Technical Q & A Forum😎
| All times are GMT -5. The time now is 12:01 PM. |
