-   -   XR pinion needle bearing help (https://www.offshoreonly.com/forums/drives-lower-units/373296-xr-pinion-needle-bearing-help.html)
312fastec 09-11-2021 07:26 AM
XR lower pinion bearing roller help
hi all, does anyone have an easy solution to remove the pinion bearing roller from the lower tower? I have esseiller 100 puller I heat I have no idea I believe in more that was mounted in the locktite
these some have a solution I would be interested thank you all
JaayTeee 09-11-2021 08:47 AM
https://www.mercruiserparts.com/bam/...0990/10270/130
#7 ? If so, it will drive straight through, rig something up slightly smaller than the o d of the race and drive it out through the bottom
312fastec 09-11-2021 09:17 AM
No sorry the lower #6 parts number 31-86754T
253 09-11-2021 09:31 AM
a 7/8 socket works perfect,,put an extension on the socket and drive it out,,some housing have a lip just below the needle bearing,,if so turn it upside down and drive it out.
Unlimited jd 09-11-2021 10:11 AM
#6 is the race on the outside of the tower, merc has a multi piece puller that goes over it, and a threaded rod pulls it up. Tough to do without the right tool
312fastec 09-11-2021 10:19 AM
yes I have the tool but it has broken the lip of the bearing so I am not sitting down to remove it
