-   -   Bravo 1 OM drive assembly (https://www.offshoreonly.com/forums/drives-lower-units/376344-bravo-1-om-drive-assembly.html)
jps9287 07-11-2022 02:03 AM
Hello I had oil in my bellows so I replaced the necessary seals to fix the problem. My shaft did not have a race shim or washer. It doesn’t appear that there is a stamp on the back of the drive either. Drive is OM117251
thanks in advance.
JaayTeee 07-11-2022 06:03 AM
They made a change sometime in the OM serial # group from a
non shimmable pinion to a shimmable pinion, the newer ones have
the inner race that has a shoulder incorporated into it, the olders
had the shoulder as a separate piece is how you would tell the difference
the older units didn’t use shims
jps9287 07-11-2022 06:14 AM
Ok if it didn’t have them I’m assuming it is an older unit.
