Lock nut part # 11-862903 vs 11-859116
I ordered 11-862903 lock nut for swivel shaft u-bolt on a bravo transom. I got 11-859116 instead (same as for the 6 bolts holding the outdrive to the bell housing) and none of the retailers I'm looking at stock the first one. Some redirects to the 11-859116. Is 11862903 obsolete? It's obviously two different part numbers, and the original lock nuts on my transom assembly (manufacturing date oct 2020) has Red nyloc on them, vs the white/grey on the bell housing. I'm thinking the nyloc is different between the two?
Also, according to Hardin Marine, the two nuts are different sizes: 11-862903 is .375-24 11-859116 is .4375-20 I don't get it.. |
https://www.mercruiserparts.com/862903-nut
3/8 vs 7/16 threads I'm not seeing 11868903 show up anywhere? You sure of that PN? |
Originally Posted by DrFeelgood
(Post 4838247)
I found this while searching
REC11-862903. Equal to. Mercruiser OEM: 11-134371, 11-82671013 |
Originally Posted by rokj
(Post 4838250)
That was a typo, corrected it. Going to check my new U-bolt, might be that the changed the threads. Still, do you think there could be a difference in seize power of the two different nylocs?
| All times are GMT -5. The time now is 02:34 AM. |
