-   -   ID this drive mounting hole pattern? (https://www.offshoreonly.com/forums/drives-lower-units/377642-id-drive-mounting-hole-pattern.html)
DrFeelgood 11-08-2022 08:01 AM
At some point years ago, my boat had some big blower motors in it, and different drives. Purely out of curiosity, I'm wondering what drives were on it, and I'm hoping someone recognizes the bolt pattern (the white circles are the old holes, filled with epoxy). Open holes are Bravo.
https://cimg9.ibsrv.net/gimg/www.off...5011071c13.jpg
fastdonzi 11-30-2022 09:24 AM
Probably a Standoff Box !!!
DrFeelgood 11-30-2022 09:25 AM
Makes sense! I haven't found any drive that has a pattern like that, but I didn't think about a standoff. Thanks!
Griff 12-01-2022 12:42 AM
Ext boxes use the same bolt pattern as the transom assembly
DrFeelgood 12-01-2022 05:34 AM
Yeah, that's what I'm seeing as I scour google images. Ah well, still a mystery, I guess.
Brad Christy 12-01-2022 08:09 AM
Griff,
The bolts/studs go all the way through the extension boxes, correct? This is an assumption on my part, just thinking from an engineering standpoint....
Thanks. Brad.
(937)545-8991
Griff 12-02-2022 12:38 AM
Originally Posted by Brad Christy (Post 4852625)
Griff,
Thanks. Brad.
(937)545-8991
The Ext box bolts to the transom just like a transom assembly would and the transom assembly bolts to the Ext box separately. Stelling Boxes have have 3 bolt holes for mounting to the transom to adjust the height as desired.
https://cimg6.ibsrv.net/gimg/www.off...5e6808c960.jpg
