-   -   Bravo Vertical Shaft Splines (https://www.offshoreonly.com/forums/drives-lower-units/378220-bravo-vertical-shaft-splines.html)
Cory H 01-25-2023 06:24 PM
https://cimg9.ibsrv.net/gimg/www.off...78e0b4f18e.jpg
Slight twist in vertical shaft splines. Noticed it when ready to mate back to upper after skeg repair and repaint. Run it or repair?
Running 502mpi's in a 380 PowerQuest
Griff 01-26-2023 02:37 PM
REPLACE. Its looks like more than twist with some visible cracks.
I've put one back on that some twist, but not as bad as yours.
Brad Christy 01-26-2023 02:44 PM
Cory,
I don't really know a DAMNED thing about the intricacies of outdrives, but I agree with Griff. You're starting to see some shear in those splines, not just twist. Just from a failure analysis standpoint, it's time for it to go.
Thanks. Brad.
(937)545-8991
compedgemarine 01-26-2023 03:45 PM
I guess it would depend on if your seatow membership is paid up, you will need them with that shaft
Cory H 01-26-2023 06:21 PM
Is that just a swap out part, or reset up shims? How many hours labor should I expect?
AllDodge 01-27-2023 07:20 AM
The entire house will be disassembled to get to the bolt that holds the gear on the shaft
https://www.mercruiserparts.com/bam/...30967/1943/220
Need to check shims and or change, I would guess a couple hours for someone who does it a lot
Edit: might find other things that need replacing once inside and things a measured
ThisIsLivin 02-14-2023 09:40 AM
I can guarantee that the gears in the upper will fail soon have them checked. Ask me how I know.
clavoie629 02-23-2023 02:13 PM
I had a couple that looked just like this seems to be a weak spot. need a fast arm
Cory H 02-27-2023 11:48 AM
Well, this would have happened three years ago and close to 200hrs of use. Would have never known, had I not pulled lower to have a skeg welded. Now hopefully, port drive is ok. It was fresh with new gears and bearings 3yrs ago.
