-   -   bravo III question (https://www.offshoreonly.com/forums/drives-lower-units/379602-bravo-iii-question.html)
cloudmaster_321 06-15-2023 01:11 PM
bravo III question
I have a spare bravo III drive, straight back. Has just the one anode under the cavitation plate. It has a crack in the housing. Will the new style lower housing with the twin anodes bolt up to my upper? Or will it only bolt up to the newer style swept back style uppers?
Knot 4 Me 06-19-2023 03:57 PM
My straight back BIII had both anodes. You can see them in this pic.
https://cimg5.ibsrv.net/gimg/www.off...51dce9101a.jpg
AllDodge 06-19-2023 04:34 PM
Depends on the age. Here is the comparability chart
https://cimg3.ibsrv.net/gimg/www.off...7e24330c39.jpg
cloudmaster_321 06-20-2023 12:31 PM
ok... wow, that's a lot of differences.......
AllDodge 06-20-2023 12:42 PM
The last change in housing was after 1993 so far as interchangeability
cloudmaster_321 06-20-2023 01:01 PM
My drive is from 2001. Single anode though.
AllDodge 06-20-2023 01:04 PM
ok, after 1993 upper and lower did not change so far as newer fitting older. Get a 2023 to 1994 and they should all fit.
Knot 4 Me 06-20-2023 01:13 PM
Mine was an '04, last year before the swept-back came out.
AllDodge 06-20-2023 01:23 PM
My 94 27PC came with the 2 piece B3 lower. Picked up a newer 2000 something complete with 1 anode and the lower fit. Later bought a brand new B3 complete (2 anodes) for repower and the gear ratio was to high. Took the new lower off and installed the 2000 something and was still working when I sold the boat this year. Still have the B3 lower
cloudmaster_321 06-20-2023 02:06 PM
mine is a 2.20 ratio
AllDodge 06-20-2023 02:16 PM
Mine would be to high, yours should have come with 30/23 uppers and 16/27 lower gears
Mine was a XR B3 and said to be 1.81 but XR only comes with 19/16 uppers, so closest to the 1.81 was most likely 15/19 which would be used for the 1.50 drive ratio
AllDodge 06-20-2023 02:45 PM
Rotated the upper and counted rotations of both, 10 upper/7.25 lower 10/7.25= 1.379
Believe mine is a 18/25 25/18 = 1.38 making it for a 1.65 drive using upper of 32/27 only one with that ratio
Other lowers are 15/19 = 1.27 , 16/27 = 1.68 , 13/24 = 1.85
