-   -   Volvo 270 Outdrive and PDS bearing replacement (https://www.offshoreonly.com/forums/drives-lower-units/382258-volvo-270-outdrive-pds-bearing-replacement.html)
Tahiti25 06-04-2024 05:16 PM
Originally Posted by Lancer19 (Post 4896419)
Ok, so it states I can't post photos until 10 posts?
What about through tapatalk?
You have a double bearing housing . Single bearing housing was used quite a bit later. Looks like a 270 drive to me.
Mbam 06-05-2024 07:13 AM
Fun useful fact -
The mounting ring (37) has a few holes that are tapped the same thread as the mounting bolts (40). I think it's 3 but not sure.
Put grease or antisieze on a few of the bolts and put them in those holes then run the bolts in to pull the ring off. It can be difficult to remove.
Someplace in my archives I have a couple of alignment tools that one of the race guys made up to get the engine mounted in the right place. I'll try and post some pix later.
