Syncing trim rate on twin Bravos
Baja 342, throttle trim switch does not extend or retract drives at same rate. Simultaneously pressing trim rocker switches does not make a difference. I switched cylinders from drive to drive to see if the slower(starboard) drive would follow the cylinders over to the port drive. No change. I am suspecting a weaker motor on the Starboard pump. My question is, if there is anyway to adjust flow rate to compensate? Is there an after market in line flow regulator available? I am afraid if I replace the 20+ year old starboard pump motor with new, then it would now be faster than the 20+ year old port pump motor and I would have to replace it also. Then what if they still were not in sync? I would rather just regulate one pump to match the other. Has anyone else had this issue?
What bencini said. It was a game changer for my boat.
Originally Posted by IGetWet
(Post 4900955)
Ahh, yea you will need electronic senders on the drives for this to work.
It monitors the voltage output of the sender and adjusts the trim (operates the pump) to match them up. |
(Post 4900964)
Spec for the pumps is 30w oil. Could try running 50w in the faster pump and a 0-20 in the slower pump
Originally Posted by Griff
(Post 4901043)
| All times are GMT -5. The time now is 03:44 PM. |
