Help identifying gear ratio for Bravo 1?
Hi, I like to know gear ratio for my Bravo 1 / 377 MAG, bought as a complete unit 2014 by previous owner.
I have problems finding a prop that works for me, so I need to start finding the gear ratio for the drive. Engine number is 2A443075 Drive number is 2A418704 Any one able to help me find that out? I have seen in older posts someone have searched by the identification numbers. Regards Retro2 |
Originally Posted by Retro2
(Post 4906560)
I have problems finding a prop that works for me, so I need to start finding the gear ratio for the drive. Engine number is 2A443075 Drive number is 2A418704 Any one able to help me find that out? I have seen in older posts someone have searched by the identification numbers. Regards Retro2 Mercruiser sterndrives and sterndrive information |
OK, thank you. Those numbers was what I could find in the insurance papers.
I'll see if I can find some more. |
(Post 4906560)
I have problems finding a prop that works for me, so I need to start finding the gear ratio for the drive. Engine number is 2A443075 Drive number is 2A418704 Any one able to help me find that out? I have seen in older posts someone have searched by the identification numbers. Regards Retro2 The 2A for the serial is valid, they ran out of numbers that start with 0 a while ago. |
Thank you. then I have to find the numbers on the drive it self when my boat is out of the water.
You don't know if there is a "standard" gear ratio delivered with the 377 MAG? |
If you pull the drive, mark the drive shaft and prop shaft. Rotate the drive shaft 10 times and count prop, then divide by 10
OK thank you, I do know about that. Just liked to try find out while the boat is still in the water. :)
Hello Bajaman, i want to ask you if you know.
One sterndrive like bravo1 that was in diesel engine with ratio 1,5 to 1 is the same with an other bravo1 that was in petrol engine with the same ratio? |
| All times are GMT -5. The time now is 03:32 AM. |
