cleaning resevoir
About to change the drive lube on my XR and also want to clean the reservoir. What is a good for cleaning it. Alcohol???
Thanks, Padraig |
Originally Posted by Padraig
(Post 4928387)
Thanks, Padraig |
Anything known by the state of cancer to cause california will do..
You want something that will suspend the contamination so it can pour or eipe out etc. Even warm water with a detergent would work...
Depends on where you are...water also causes cancer...in CA. |
(Post 4928387)
Thanks, Padraig |
Originally Posted by Baja_260
(Post 4929486)
Just curious what you used. I tried acetone last night, no good. It liquified the small amount of blackish brown gunk on the bottom of one of my reservoirs into some nasty funk that’s now stuck to the entire inside of the reservoir.
Padraig |
(Post 4929504)
Mine wasn't bad and I used some kerosene as suggested.
Padraig |
I use mineral spirts, a rag and screw driver the wipe it clean every change. Of course the bottle is off when I do this.
(Post 4929507)
(Post 4929486)
| All times are GMT -5. The time now is 04:29 PM. |
