-   -   Bravo Three stripdown and re-paint (https://www.offshoreonly.com/forums/drives-lower-units/388140-bravo-three-stripdown-re-paint.html)
Sparkfarmer 05-31-2026 04:51 PM
Hey everyone,
New here and I'm trying to send a PM to buy a part. Instead of spamming an old post I thought I'd share a few pics of my project. Bought a new to me 2004 Doral Intrigue. Salt water had started to take it's toll on the finish, and one of the skegs had some damage from galvanic corrosion.
Sparkfarmer 05-31-2026 04:57 PM
Dirty ol' drive
https://cimg1.ibsrv.net/gimg/www.off...c513f55dba.png
Sparkfarmer 05-31-2026 04:59 PM
Galvanic corrosion on the skeg
https://cimg7.ibsrv.net/gimg/www.off...b5cd9c7ac2.png
Sparkfarmer 05-31-2026 05:00 PM
Tig weld repair
https://cimg9.ibsrv.net/gimg/www.off...305537088.jpeg
https://cimg2.ibsrv.net/gimg/www.off...390ac9199.jpeg
Sparkfarmer 05-31-2026 05:02 PM
Sandblasted drives
https://cimg7.ibsrv.net/gimg/www.off...bf6112713.jpeg
Sparkfarmer 05-31-2026 05:12 PM
C-IC 33 Aero (Alumiprep)
Drawing from my background in aircraft maintenance, I prepared the aluminum drives for paint using the same techniques recommended by aircraft manufacturers. Alumiprep is a phosphoric acid-based cleaner. It's used to remove the oxidation layer on aluminum. Only difference is I diluted the Alumiprep with water as the drives are cast. Come to find out, the Mercury Bravo Three shop manual recommends the exact same process. I only stumbled on that info afterwards while browsing the manual.
https://cimg2.ibsrv.net/gimg/www.off...e2e9156d4.jpeg
Alumiprep treatment
Sparkfarmer 05-31-2026 05:17 PM
Alodine
Immediately after the Alumiprep treatment, I applied Alodine to provide a good conversion coating to promote paint adhesion.
https://cimg1.ibsrv.net/gimg/www.off...aa0f73598b.png
Sparkfarmer 05-31-2026 05:19 PM
Interprotect 2000e
I then sprayed 5 coats of Interproject epoxy primer
https://cimg4.ibsrv.net/gimg/www.off...fa4927775.jpeg
https://cimg5.ibsrv.net/gimg/www.off...9fa994d3c.jpeg
Sparkfarmer 05-31-2026 05:23 PM
AWLGrip
Then finished it off with 3 coats of AWLGrip AWLCraft 3000.
https://cimg4.ibsrv.net/gimg/www.off...f7fb7b7bc0.png
Sparkfarmer 05-31-2026 05:24 PM
Pretty happy with the results. We'll see how well it holds up. :D
