Bravo hinge pin side to side play
Hi all, as im learning more about drives I've noticed left and right play in my hinge pin pivots. The pins themselves don't move just the drive does left and right maybe about .020. I can't upload a video or i would. Im wondering what is allowed if any? I guess there are 2 washer/spacers that go in there according to diagrams? Also my upper unit is contacting my transom plate at times as well on on the one side. Not sure how much of this is normal. Thanks
https://cimg8.ibsrv.net/gimg/www.off...79c006f21e.jpg |
You have to upload video to youtube and link it.
You need a set of wear pads for sure. They clip on to where the bare metal is in your pic |
Originally Posted by Griff
(Post 4948351)
You need a set of wear pads for sure. They clip on to where the bare metal is in your pic Amazon.com: Wear Pad Kit Mercury - Mercruiser 805261A-1 by MerCruiser : Automotive |
Here is the video link
https://www.mercruiserparts.com/bam/...58108/28143935
my guess would be that part number 4 is bad. it should be a fiber washer for wear. your is an early unit and I dont think it uses the plastic pads that Griff was showing. |
Originally Posted by compedgemarine
(Post 4948403)
my guess would be that part number 4 is bad. it should be a fiber washer for wear. your is an early unit and I dont think it uses the plastic pads that Griff was showing. https://cimg6.ibsrv.net/gimg/www.off...cbc301f044.jpg |
8 should be a stainless washer. the one I listed is the fiber washer. when all new there is not much play. yours is way more that a new one.
| All times are GMT -5. The time now is 10:18 PM. |
