Go Back  Offshoreonly.com > Technical > Electronics
NMEA 2k trim tab indicatorss? >
Old 10-27-2014 | 06:51 AM
When I spoke with noland the current version has trim but not tabs. So you need to spoof it a little to get it all. Other than that it is a really nicely done unit.
Steve
smiklos@sunprint is offline
Old 03-14-2015 | 05:03 PM
beating a potentially dead horse? .... I do not have smartcraft, but intend on getting a analog converter to integrate my engine vitals on two Garmin screens.... would love to minimize clutter on my dash and integrate my k-planes onto garmin screens NMEA 2000. still not really possible without purchasing the Livorsi setup?
(single engine boat with k-planes)
Shibby1485 is offline
Old 03-15-2015 | 06:56 AM
The Noland unit will work.
Steve
Old 03-26-2015 | 04:23 AM
Looks like I should be able to use 1 of these Noland units to convert 2 tabs, 2 drives, and 2 fuel tank levels into names 2000...
Has anyone got 1 of these units up and running ? Should be possible to fab up a trim pot mechanism to hook to short 33 c cables like the livorsi units.
delsol is offline
Old 03-26-2015 | 04:43 AM
Yeah I think I actually posted to the parts to do that on here somewhere. Basically just need a variable resistor setup to convert the cable or piston movement to an electrical signal. I take it you have cables on everything now?
kidturbo is offline
Old 03-26-2015 | 07:05 AM
I have it running using smartcraft sender's from tabs and a 0-5 v tps on drive indicator.
Steve
Old 03-26-2015 | 08:06 AM
My Noland box arrives today! Very excited and intrigued to tinker with it.
Hope you fellas won't mind my picking your minds on this exact topic: trim tabs. Especially you steve. Read lots of ur threads.
Another steve here as well
Old 03-26-2015 | 08:22 AM
Yes -- cables currently
I looked at the Honeywell units --- they look like the ticket for the conversion. I need to measure travel on the drives and tabs in order to pick out the most suited linear Transducer. I will be ordering one soon in order to mock it up.
Smiklos--- we're you able to get the screen to look right? You mentioned having to spoof it a bit--- I take it that is the setup....
delsol is offline
Old 03-26-2015 | 06:57 PM
got my RS11 today but i'm about a month+ from any connectivity and running live with it. sharing this from Noland website
Originally Posted by Noland Wesbite
RS11v4 3.45 Firmware Upgrade
A software update package version 3.45 is available for the RS11 v4 units. This upgrade adds soft alarm assignments and entering engine hour resets values up to a 5 digit number. Other updates include ppr entry up to 300 ppr,better resolution for low ppr values, added Trim Tab Field to Analog selections, and storing settings data on the RS11.
Old 03-27-2015 | 06:47 AM
Funny you say the Honeywell unit I just put one in the raceboat on stainless marine heads up indicator. The magnet is on cable and the bar is in front of it. seems to work good I am using it for a racepak sensor.
Steve
