-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   NMEA 2k trim tab indicatorss? (https://www.offshoreonly.com/forums/electronics/306217-nmea-2k-trim-tab-indicatorss.html)
kidturbo 03-28-2015 01:32 PM
Thanks for that info Steve. I believe that is exactly what Delsol needed to know for his setup. Standard 0-5V signal correct?
delsol 03-28-2015 01:54 PM
Yes thanks Steve.
I'm also looking into the standard Merc sending units for the drives and trim -- how are they holding up? By using the merc units it takes all the slop out of the cable set ups...and is very clean inside the transom.
delsol 03-28-2015 01:56 PM
Would it be possible to mount the magnet inside of the hydraulic cylinder on the tabs and strap the Honeywell on the outside?
Or easier would be just make a bracket that mount to the end of the cylinder and held the magnet over the unit mounted on the cylinder housing...?
smiklos@sunprint 03-29-2015 08:14 AM
I was think of that for a steering ram for steering position. I really do not think it will work but we may try it.
Steve
smiklos@sunprint 03-29-2015 08:16 AM
You meed about 3.75 inches of travel for anything with cables.
Steve
