-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Speaker static (https://www.offshoreonly.com/forums/electronics/314374-speaker-static.html)
US1 Fountain 06-26-2014 04:14 PM
Speaker static
Replaced JL 300/4 amp with a 600/4 amp. Simple undo wires and reinstall on new amp. Now when I hit my drive trim switches the speakers crackle with static. Any thoughts on why or how to correct?
a262carl 06-26-2014 06:49 PM
I think id star by checking the ground. Maybe even run it directly to the battery if you havnt done so already
4bus 06-26-2014 06:58 PM
Check ground like stated above. Make sure power wires are clear of RCA and speaker wires, they can send rf through.
tomtbone1993 06-26-2014 07:08 PM
What short bus said...like 18" away from each other.
Couginitnordic 06-26-2014 08:22 PM
The new amp could be more susceptible to noise in the design. I see many companies cheapen out their stuff to save a buck. You may need a choke of some kind but check all of your wiring like the others said. That is the real way to fix it.
Pliant 06-26-2014 09:33 PM
The fact that the amp pops during a voltage variation is due to improper isolation...ground straps are 99.9 % of the problem....Now there is a very small chance your getting a power spike in your remote amp on circut...look closely and see if there are any small wire threads lose near that power node.
commandersander 06-27-2014 03:57 PM
Pull amp and head power at the same point.....same with ground
US1 Fountain 06-28-2014 12:22 AM
I've had the head unit powered thru the factory stereo wiring power leads. Tried running HU ground to my amps power junction blocks which are amp only dedicated power runs. All good now. The new amp is just a little more sensitive being new technology. thanks!
commandersander 07-01-2014 10:05 PM
Nice!!!
glassdave 07-02-2014 08:06 AM
had a full JL system put in a customers TG used a 900/5. Incredible amp, I cant get over how crystal clear the separation is between sound and silence. Wish this clip could do it justice but its one of those things ya gotta hear in person. I made this clip cuz i wanted to get that song he uses to tune but then i remembered it just aint gonna sound like this in my circa 90's crap that came in my Scarab lol
https://www.youtube.com/watch?v=rK5aAlEqiZI&list=UUOM47fb_NbOZJbUuUYUMzMQ
