-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Gaffrig GPS Wiring (https://www.offshoreonly.com/forums/electronics/327154-gaffrig-gps-wiring.html)
Superman09 06-09-2015 08:13 AM
Gaffrig GPS Wiring
Picked up a Gaffrig GPS Speedometer w/ recall. Instructions sent with show the older style gauge wiring and the gauge included simply has wires coming out of it, no posts like the old style.
So far I have it wired as follows and it does not work, nor do anything at key on to find a signal. Only thing that works is the red back light comes on with my other lights.
Gauge: Red to power, Black to Ground, White to the Grey wire on GPS Receiver, Purple to same power as Red, Green to Top Speed recall switch which is grounded.
Antenna: Red to power, Black/Orange to Ground
Any ideas, have not gotten any movement out of the gauge other than the red backlight. Thanks!
phragle 06-09-2015 11:25 AM
1 Attachment(s)
try this
[ATTACH=CONFIG]541989[/ATTACH]
Superman09 06-09-2015 11:33 AM
Yep, exactly how I had it, nothing. When I power on I get a buzz but the needle never moves. Buzzes for about 2 seconds and then quiet.
Dave M 06-09-2015 12:44 PM
You have the signal wired to your GPS, or an antenna? If you are using a GPS you have to go into the "setup" menu and enable NMEA output.
Superman09 06-09-2015 01:46 PM
Yeah, I ran the white wire to the grey wire for the signal. I power on and don't have any action, needle doesn't move at all. How would you get to the "menu"?
drpete3 06-09-2015 01:48 PM
even if the NEMA is not turned on on a chartplotter it shoulod power up and cycle. Have you checked to be sure your red is getting 12v? ground is grounded? Dont take my word on this but it sounds like you have everything correct and you may have a dead GPS which Livorsi is no longer fixing. Hope you get it worked out
Superman09 06-09-2015 01:56 PM
Yeah the 12v and grounds are both good. The back light works as well. I was thinking a bad unit but wanted to confirm I didn't have some wiring wrong first. I have an e-mail in with Gaffrig now for some help, thanks!
Superman09 06-09-2015 01:59 PM
FYI for anyone else looking for the wiring info, I just got this from Gaffrig:
Wiring:
RED FROM GAUGE TO RED ON RECEIVER THEN TO +12VDC IGNITION POWER (usually purple or violet in a boat)
BLACK FROM GAUGE TO BOTH BLACK AND ORANGE ON RECEIVER THEN TO – ENGINE GROUND
WHITE FROM GAUGE TO GREY ON RECEIVER FOR SIGNAL WIRES
PURPLE FROM GAUGE TO +12VDC POWER FOR LIGHTING(usually blue in a boat)
GREEN FROM GAUGE TO ONE OF THE TERMINALS ON THE RECALL SWITCH AND THEN THE OTHER TERMINAL ON THE RECALL SWITCH GOES TO GROUND, THIS IS OPTIONAL. DO NOT HOOK GREEN WIRE OR SWITCH TO +12VDC POWER BECAUSE YOU WILL BLOW THE GAUGE OR RECEIVER.
drpete3 06-09-2015 03:28 PM
Wiring:
That sounds like what you wrote in the beginning...........Is it working? What am I missing?
daniel475 08-18-2016 12:25 AM
did this ever get figured out im having the same problem
