best way to wire dvc subs
im installing a new sound system in my boat
have 2 jl audio 400/4 amps going to 2-12" dvc subs and 6 6x9s ? is what is best way/sound to wire the subs radio has L&R ouputs for subs and set amp at low imp and going to use 2 channels on the amp for subs other 2 for 6x9 s if wire the dual voice coil subs separately as L&R parallel to both coils that takes them to 2 ohm in series to both coils goes to 8 ohms' to 1 coil only stays 4 ohms but will it sound good only using 1 coil if bridge the 2 channels at amp and wire both speakers together in series will stay 4 ohms just trying to wire for best clarity for power I have |
Wire both subs to 2 ohms and run one on each channel. Some 4 channel amps have a pair of channels for mid/highs and 2 channels for lows so double check that to determine which channels you are going to use.
tks
at 2 ohms separately the amp gives its full 100 rms watts to them was just making sure best way for the power I have to them for best sound I have the new jl audio xd400/4v2 amps all 4 channels adjustable for subs |
100 watts is probably no where near enough power. What is the RMS power requirements of the sub? That is only 50 watts per voice coil. I don't know of any JL sub that, that will be enough power.
If that xd is regulated i would try 2 ohms first . Kind of a odd set up your working with there . 12w6 0r 7 prob need to get a worthy sub amp . Polk or some other dvc subs expediment. Most wont condone running seperate voice coils from seperate channels. Jls unregulated amps can draw some amps and get sloppy at 2 ohms .
you could always put your xd on 6x9s and get a class d mono for these subs of yours. If they are 3 ohm w6 or7 series get a750.1or 1000.1 and dont look back .unless you have 2 120 amp alts on this boat of yours. |
Or just bridge your xd into a 2 ch into 2 2 ohm subs and see if it makes you happy . Seal the dog doo out of what im imagining is a bench seat . Put bright light in the seat at night and seal until you see no light come out the front sides or where seat bottom rests on lower structure
1 Attachment(s)
yes im limited on battery power
2 400s and another sub amp will be a lot for my set up I have triple 260+hp 2.5 offshores on this little 27 ex the racing ignitions are only 16 amps I have the 3 motors running on 2 27 series agm batterys I knew boat needed ballast in front so I had a 30 gallon fuel tank made down in front v with a 12gpm transfer pump to move weight around and another deep cycle 31 series agm battery up there just for stereo only,,,,,nothing else tied on it and a battery switch to separate from 2 others so when motors not running switch off to the 1 only battery on radio so not to kill the motor batterys what I have is 2 jl 400/4s 2 jl 360/4s and did buy polk audio speakers db1240 woofers are 360rms and 720 max 6 6x9 100 rms I can bridge the 1 400 to 2 channel for subs and just use 4 6x9 but I was thinking using the 6 6x9 and just putting a little power to the subs for now to see how long the 1 battery last when motors are off with the 2 amps yea I don't have the luxury of big alternators so open to all suggestioins would like the small cockpit to rock as good as boat scoots 2 subs are under dash in the vertical boxes on gunnels for wiring and hoses all sealed 2 6x9s under there also cutting in 2 more in side panels beside rear bench and 2 more in bottom of rear bench will a dvc woofer sound ok on just 1 power input to 1 coil only? here is pic of how small I have to work with only 5'5" between winshield with no front birth just carpet straight dash no cabin door [ATTACH=CONFIG]542452[/ATTACH] |
Damn how fast is that thing?
Chris |
Those polk dvc subs are flexible , they will self destruct real quickly in a bad install though. Wire at 1 4ohm coil for
minimum amp draw. if you can move from that 400/4 to a 500.1 for subs it would be better on alts (or stators)and louder . |
I think you need to sell your amps and find some different ones. You can find JL 600/6 for around $400 and find a 500/1 for the two subs. You are wanting a similar setup as I have. I think different amps is what you are going to need.
| All times are GMT -5. The time now is 05:16 PM. |
