-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Wet Sounds 808 (https://www.offshoreonly.com/forums/electronics/338441-wet-sounds-808-a.html)
jonyb 07-14-2016 10:28 PM
Originally Posted by Captain YARRR (Post 4459783)
So you're saying as a first step, four 808s in the cockpit and 2 650s in the cabin is a nice place to start?
Obviously the subs would be a next step, but that's one that can be done in isolation so it doesn't influence the first step.
I honestly wouldn't waste any time or money on the cabin speakers, unless you want it loud in there. If you use the Sinister amps, I recommend 1 808 per channel. You can pair 2 650's per channel on that amp too. If you really want the cabin speakers, you could set up front to rear fade, that way you can turn down the cabin.
Captain YARRR 07-14-2016 10:32 PM
In a perfect world I think I should probably run the cabin speakers off the head unit then the four 808s on whatever matches well.
jonyb 07-14-2016 11:42 PM
If you do that, you'll need something more efficient. 650's won't work too well on a head unit. Impedance is about 3.7 ohm
Captain YARRR 07-15-2016 07:26 AM
Maybe I'll leave the Sony stuff in the cabin since it is already crazy loud in there.
Captain YARRR 07-15-2016 07:37 AM
Tell me about using using the Sinister vs SYN DX for my application. Is it just that the Sinister has a little extra power over the 808 rating?
jonyb 07-15-2016 11:27 PM
99% of the boats I've done have all left the cabin speakers alone, unless they were trashed.
jonyb 07-15-2016 11:29 PM
Yes, the Sinister is a better platform. Both are great amps, the Sinister amps just have bigger balls. Both are class D, so they're the most efficient and won't have thermal issues.
alindquist 07-16-2016 08:19 AM
I have a set in the boat & a set on the transom. I also have a set of 650's in the arch, all ran with SD amps... Sounds good to me. I'm not real impressed with the 10's but they are a free air sub so they will never pound like a good sub in a custom built sealed or ported box...
jonyb 07-16-2016 11:46 PM
I can agree with that when you don't use an enclosure, but that goes for just about any infinite baffle speaker. The XS10FA's do okay with around 1 to 1.2 cu ft.
Captain YARRR 07-18-2016 01:00 PM
Looks like for the money, I might as well buy the six channel and find a place for another pair of 808s. Haven't heard them before but I'm guessing at 150 RMS a speaker...x6 it will be plenty loud.
