-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   525 computer reflash by whipple???? Option?? (https://www.offshoreonly.com/forums/electronics/341108-525-computer-reflash-whipple-option.html)
waynepaul 09-09-2016 08:28 PM
Have been kicking this around as a winter upgrade.. Worth the $800 problems??
Ryan00TJ 09-10-2016 12:41 AM
http://www.offshoreonly.com/forums/g...m-upgrade.html
Good info here.
joketchum 10-04-2016 03:32 PM
gives you better midrange and also if you have a soot problem on the transom after running it for the day, you will have significantly less. My props will only turn 5300 right now so I'm not taking advantage of the 6000 rpm rev limit, probably best on stock springs
