spade to ring connectors
I want to change my guages. I currently have VDO that have spade connectors, to guages that have ring teminals. I keep hearing that there are spade to ring conversion connectors? Has anyone heard of these and where can I get them? Thanks
Napa But they are called something else and I cant remember
Not sure how livorsi gauges are, but my autometer set came with 90 degree male spades attached to the gauges with a 6-32 nut on a stud. I removed the 90 degree male spade and used ring terminals directly on the 6-32 studs.
I placed a washer on the stud, then a primary nut, followed by the ring terminal and then another nut |
SOMETHING LIKE THIS?
http://www.newark.com/te-connectivit...-35/dp/52R3951 OR LIKE THIS 100 PC. PACK? http://www.allbatterysalesandservice...fm/4,2690.html |
I don't see why you would want to introduce another termination to the circuit. You still have the spade female to male and are only adding a "nut and bolt" ring to ring splice.
I think it will just be easier than having to cut off all the female spades and put on all the ring connectors.
Check here: www.partsexpress.com
This place has a ton of cool stuff. Been getting things from them for about 14-15 yrs. |
Originally Posted by GLENAMY 242SS
(Post 4496673)
Mcmaster Carr has them as well
https://www.mcmaster.com/#standard-e...inals/=14uzaw1 |
| All times are GMT -5. The time now is 03:06 AM. |
