-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Hooked up Battery and accidently Reversed Polarity (https://www.offshoreonly.com/forums/electronics/346444-hooked-up-battery-accidently-reversed-polarity.html)
3pointstar 04-24-2017 10:01 AM
I did the most stupid thing this morning– In fact I’m too embarrassed to really say that I did this – So be easy on me folks.
I accidently hooked up the battery wrong – positive to negative and negative to positive. When I hit the power on/off switch – the big circuit breaker popped on the engine. I shut everything off and reset the circuit breaker – pushed it in. Not knowing that the reversed polarity was the issue. – I turned it on again – with the same results.
I correctly hooked up the battery and now I have NO power anywhere. I didn’t have the key in the engine or ANYTHING like that – didn’t try to start NOTHING like that.
What did I screw up ?
I can’t put in words what kind of Idiot I feel like.
3pointstar
F-2 Speedy 04-24-2017 10:04 AM
1 Attachment(s)
Im not sure of your set up, but if its factory Mercury there will be a fuse down on the starter that supplies voltage to the top of the engine, it may of blown..and YES, it can be a mo fo to get to
3pointstar 04-24-2017 10:41 AM
[QUOTE=F
F-2 Thank you so much
Just got off the phone with the marina
a) Blew out the solenoid to the starter
b) Fried the battery
Should be around $300.00 for new battery (1000crank amps) labor and $30.00 part solenoid
Thank the Lord that was all there was.
3pointstar
ALL_IN! 04-24-2017 12:40 PM
I'd be surprised if that fuse is not blown.
3pointstar 04-24-2017 02:46 PM
All that responded - thank you so much - I'm not a mechanic-- URGH
The solenoid to the starter was fried and yes the Fuse took one for the team. The battery was something that was a little more expensive at the Marina but they were able to get this in and out in a couple of hours - it was worth every penny.
Again guys thank you for your inputs.
3pointstar
SB 04-24-2017 03:08 PM
You did get lucky. You should see what happens to some cars when this happens. Big ol' OMG !
Dave M 04-25-2017 06:38 AM
Glad it worked out for you. Chances are you won't do that again, but I would rig the battery cables better to avoid the possibility of that happening.
3pointstar 04-25-2017 07:07 AM
The long and short of this entire mess was me not taking time to do the work. I have everything color coded and I was in too much of a hurry to think first. I will say this much on the top of the positive terminal I'm going to cut a cross in it and fill it with some white nail polish. Belt and suspenders
3 pointstar
tommymonza 04-25-2017 11:08 AM
Better check your alternator too , unless it has a fusible link, the alternator is most likely fried too.
Don't ask me how I know.
